Ben un des mes clients m'a dirigé sur une adresse sur le net www.automec.co.uk en disant que ce liquide de frein serai apparemment,je cite : "c'est le liquide de frein miracle !"
Silicone Brake and Clutch Fluid DOT5
Made in the USA-used exclusively by the US Military and specified as standard by Harley Davidson. Non-toxic and long-life, silicone fluid is safer and more user-friendly than glycol. It never needs changing, will not catch fire easily and does not damage paintwork; neither will it boil below 260°C (500°F), even after 5 years. Non-hygroscopic (i.e. will not pick up moisture, thus reducing corrosion), silicone fluid retains a virtually stable viscosity through most temperature extremes.
Conforms to US DOT5 standard and US Federal Motor Vehicle Safety Standard 116 (FMVss116). High-visibility green/yellow packaging includes tie-on-tag to prevent user from inadvertently topping up with glycol.
dites moi ce que vous en pensez !! et si qq1 en a déja entendu parlez ?? ![]()
